Marek
AI 9.5 Problem with BuildProject dialog
I have two monitors configured like one virtual desktop.
I placed the BuildProject dialog on second monitor (2) after click Build button in AI. My project building correctly and I close the AI.
After that I moved the second monitor in another position like this.
I turned on again the AI and I clicked Build button. The BuildProject dialog does not shown up on the desktop. But it was only an illusion because the dialog showed up in the old position when the second monitor was in the position shown in the first image (1.png). This creates a problem in use of the program, because you can not click the OK button on the BuildProject dialog and continue. Probably dialog remembers your location and displays again in the old location. In my opinion you have to check whether position of dialog is correct with current size and coordinates of the desktop before the dialog is displayed.
mihai.petcu
Re: AI 9.5 Problem with BuildProject dialog
Thank you for reporting this, I have added the issue on our TODO list and the fix should be available in a future version.
