jusher
Security settings error
See attached file.
Any idea why this occurs? CHOPPER is the name of the machine and also the Instance Name I am using on SQL Server 2000.
The installation stops the connection string I am using and I often use is: -
Driver=SQL Server;Server=[SQL_PRIMARY_HOST];Port=1433;Uid=[SQL_PRIMARY_USERNAME];Pwd=[SQL_PRIMARY_PASSWORD];Database=master;
John
Re: Security settings error
Hello John,
I'm not sure why you are encountering this behavior. However, you can take a look on our "Non US version of XP and Creator Owner Group" thread in order to avoid this issue.
Let us know if this helps, otherwise give us more details about your scenario.
