dswartley
Quick Launch Shortcut Not Being Created
I saw some other threads on the topic buy they are years old, so I am starting a new one.
I added a shortcut in the Application Data\Microsoft\Internet Explorer\Quick Launch folder, but it never shows up. The shortcuts I created in the Desktop and Program Files folders work perfectly, but quick launch doesn't ever show up.
Is there a step I am missing somewhere?
mihai.petcu
Re: Quick Launch Shortcut Not Being Created
Hi and welcome to Advanced Installer forums,
I just tested this and it works as expected if you place the shortcut from the Files and Folders page. Are you looking in the right location (Paths of the folders in the "Files and Folders" Page article)?
dswartley
mihai.petcu wrote:Hi and welcome to Advanced Installer forums,
I think I'm at the right location. I've attached a screen shot.
Also you can ignore the ???, I've moved the folder that this project is housed in to another drive so it lost it's file reference, but that was after the project was built so the MSI file contains everything it should.
Quick Launch.PNG (101.76 KiB) Viewed 4599 times
mihai.petcu
The shortcut seems to be configured fine. I tested my package on a Windows Vista x64 machine and the shortcut was added correctly to the toolbar.
Can you please try on other machines as well? There's no reason why this shouldn't work.
If the behavior persists, send us a sample project with dummy files that replicates the behavior along with more details about the target OS.
dswartley
mihai.petcu wrote:Hello,
I've actually sent the install to about 30 computers, none of which got the link in Quick Launch. They are a mix of XP x86 and Win7 x64 machines.
Would part of the issue be that I'm doing silent installs? I push out our updates through a WSUS server using Local Update Publisher. I try to make everything silent so the users don't get interfered with at all. I just find it odd that the Desktop and Program File shortcuts both get placed correctly but Quick Launch doesn't...
mihai.petcu
Silent installs should have nothing to do with this behavior. Can you send us a sample project with dummy files that replicates the behavior along with more details about the target OS? We usually ask for the project file itself if it doesn't contain any vital piece of information.
dswartley
It shouldn't contain any vital information. How would I go about sending the project to you, email, an attachment...?
mihai.petcu
Sure, send it to support at advancedinstaller dot com. If it's too big you can upload it to an online location and send us the download link (e.g. Dropbox).
