amtsoft
Application tiles missing on Windows Server 2012 x64
My installation is creating the application program tiles (Windows 8 "enhancement" for the Start Menu) on Windows 8 x64 Start screen just as it should. On Windows Server 2012 x64, this is not happening. The tiles are there when you use search (the Apps screen). My installation type is "Per-machine only", "64-bit package" with Windows Server 2012 x64 enabled as a valid OS for launch conditions. I'm using V9.5 of AI. Am I missing something here?
mihai.petcu
Re: Application tiles missing on Windows Server 2012 x64
I created an installer package with the settings you specified but unfortunately I was unable to replicate the behavior on a Windows Server 2012 machine. The shortcut I added ended up in the Metro start menu as expected.
Can you please send us the project file (.AIP) to support at advancedinstaller dot com so we can investigate the issue?
amtsoft
Thank you for your prompt response. I have e-mailed you the project at support@advancedinstaller.com.
mihai.petcu
I tested the same scenario again on a Windows Server 2012 clean machine, this time using the same path as in your project (Start Menu/Programs/Prospector). The shortcut was placed as expected as a tile.
Can you please try this on another machine and see if the behavior persists?
amtsoft
I only have access to 1 computer with 2012 server.
But good news - the problem is "solved". In AI I deleted all the shortcuts for my program group in the start menu then re-created them. I built the install and it worked properly to create the tiles. The only tile it doesn't create is the shortcut to the HTML help file. I think that may be a Windows 8/2012 thing that it won't allow a tile that links to an HTML file and not a glitch in AI.
Thanks for your help on this matter especially the very fast response. Keep up the good work.
mihai.petcu
You're very welcome, glad to assist !
Let us know if you have any other doubts or queries.
