svp95bos
Unable to select "New Text File Update"
I want to add a new text file update. However, when I right click and open the context menu, the option is disabled. Am I missing prerequisite operation to be allowed to select this option?
Kind Regards,
Peter
Screenshot
Screenshot
Re: Unable to select "New Text File Update"
Hello Peter and welcome to Advanced Installer forums,
This happens because you are using a "Merge Module" project type. Please keep in mind that our "Update TXT files" feature is available only in an Enterprise or higher project type.
svp95bos
Thanks Daniel,
That solved my problem :) Yupp - I was working in a MM project...
Kind reagrds,
Peter
