Hello. i'm new in using Advanced Installer Software.
what i want to do is :
1) create an installer for my Windows Application software(Using Visual Studio 2008) and then the installer will install the software and also prerequisites(Microsoft SQL Server 2008) that will be need by the system.
btw, i want Microsoft SQL Server 2008 to install by itself and also set the database instance. what i means is user just need to click on one installer and go through it. after that the application can be used automatically without need to setting the db because installer already do that.
can i achieve this? could you please help me in step by step tutorial because i can't get solution to it and also i'm newbie.
Please help.
