typo
Client/Server Application
I have Enterprise License for Advance Installer.
i want to build one installer that will have client and server installer.
can i build separate client and server installer as exe/msi and after that i combine it by using Client/Server Application project.
can this be possible? if yes, how can i do it?
because i doesn't have any clue to start.
Re: Client/Server Application
If you want to build separate packages for Client and Server application, then you should select "Create separate packages for Client, Server and Complete installations" from the "Client/Server Application Project Wizard" -> "Configure your package structure" section. Then, you can add the related files and folders resources of the Client and Server application using the wizard.
Let us know if this helps, otherwise give us more details about you want to achieve.
