antidotcb
Installation cannot be cancelled during SQL scripts
Hi there
I have following problem.
I use several SQL scripts to be executed during installation, all of these scripts run in one connection.
When installation process goes, there is progress bar with status text on ProgressDialog.
When Status is "Executing install SQL scripts" and I press Cancel - following dialog appears:
cancel sql.png (63.8 KiB) Viewed 2844 times
I press Yes, but nothing happens, nor on button press, not later - I get successful installation, but no cancel & rollback.
Are your SQL custom actions interactive? Why installation isn't cancelled by pressing "Yes" on cancel dialog?
P.S. After SQL scripts there are several my own CA (written in C++), they are a little bit long and have different status - but whenever I want I can cancel installation and start rollback process.
Re: Installation cannot be cancelled during SQL scripts
Indeed, this is an Advanced Installer issue. The installation process cannot be cancelled during SQL Scripts execution. I have added this improvement on our TODO list and it will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
