treadmill
Administrator rights
I've created an AI installer package, which all works nicely apart from one thing, administrator rights.
The installer will need administrative rights to install the software. However, under the Installer Options, I've selected "Per-user only (with administrator rights required) and checked "Run as administrator".
The problem is that the installer never asks a standard user that attempts to run the installer to confirm an administrator login account to run the installer.
What am I doing wrong?
mihai.petcu
Re: Administrator rights
I have tested this scenario on a Vista x64 machine and everything worked as expected. A standard user will be prompted for administrator password when running the .EXE built installer.
Are you launching the .MSI?
treadmill
The Package Type is as follows:-
Single EXE setup (resources inside) and Archive installation files using LZMA compression.
Is this correct?
mihai.petcu
Yes it is, not sure why you're getting this behavior though. I initially thought you had the .MSI outside the .EXE and you were launching the .MSI.
Can you replicate this behavior on several machines? If so, can you please send us a sample project file with dummy resources and a test case so we can replicate the behavior? Our e-mail address is support at advancedinstaller dot com.
treadmill
mihai.petcu wrote:Hello,
See attached project file and screenshot. The installer never prompts a standard user for the administrator login credentials.
HES Installer WAMP.aip
(811.13 KiB) Downloaded 362 times
treadmill
I should also mention that the AI installer button shows a shield on it. I assume that's suppose to request the administrators credentials?
Jimmy
I assume this could be due to User Account Control Settings
Run GPEDIT.MSC
and make sure, you have the following set:
treadmill
Jimmy wrote:I assume this could be due to User Account Control Settings
Run GPEDIT.MSC
Thank you, I'll give that a go. :) My settings were definitely different. However, I assume these settings are default settings when an OS is installed?
Jimmy
treadmill wrote:However, I assume these settings are default settings when an OS is installed?
Not sure, we set this within a GPO in our domain, due to strange behaviour of some software, if UAC is not configured this way...
Hope it helps.
Jimmy
