Epsilon
Cannot create EXE under Windows XP Mode
I am running Windows 7 Professional 64-Bit and have Advanced Installer installed in both the main operating system and in Windows XP Mode.
When I run the same AI build under both systems, the Windows 7 works but the Windows XP Mode build fails with the error shown on the attached screenshot.
The G-Drive used in the EXE file name is an external drive mapped in the Windows XP Mode environment to the host OS Drive. The same failure occurs when I try to create the EXE file on any of the mapped drives of the Host OS.
This issue means that I can't use AI in Windows XP Mode to create the installers in folders which are also accessible to the Host OS.
Do you have any suggestions as to how I can get this to work.
Richard Williams
Failed to write EXE
Failed to write EXE
AI Could not write EXE.jpg (49.2 KiB) Viewed 3907 times
mihai.petcu
Re: Cannot create EXE under Windows XP Mode
Hi Richard,
This seems to be a permissions related issue and I don't see how Advanced Installer could influence the behavior.
You can try to manually write from XP Mode to that location (outside the installer) and troubleshoot the issue.
Epsilon
Hi Mihai
Thanks for the suggestion and I agree that it seems to be some sort of permission issue.
However, it must be an issue with the Advanced Installer Build process because I can create files using other tools from the Windows XP Mode environment on any of the drives mapped to the host OS.
In fact, the AIP file I open to run the build is also on the mapped drive and Advanced Installer can happily save changes to that file! It is only the build that fails when it tries to write the EXE file. To run the build I have to save the AIP, swap back to Windows 7 (the Host OS) open the AIP file and run the Build then return to the Windows XP Mode environment and run the newly created EXE.
Cheers
Richard
mihai.petcu
Hi Richard,
We'll have to recreate this behavior to further investigate. If there's anything particular you can help the testing team with, please send it via e-mail.
Most likely, we'll get back to you next week.
