Sangam
Custom Action -Launch file as administrator
Hi ,
I'm using custom action -"Launch file as administrator " to run my one of .exe as admin it works fine during .msi installation
but UAC box directly comes in minimize mode i want that UAC box comes in maximize mode so user can see this during installation.
Sangam
Re: Custom Action -Launch file as administrator
Hello Sangam,
I've tested your scenario, but I could not reproduce the behavior. Can you reproduce the behavior on multiple clean machines? If so, can you give us more details about your scenario? Also, can you attach a sample reproducing the behavior?
navya
Hi team,
I am using Advanced installer to make MyWebApplication as exe file.
I am trying to to use tomcat,MySQL and AppacheMq in my web Application. I am running with 2 issues when I am creating a Exe file
1)When I package my Application along with mySql Script which runs on Database. then I am getting Tomcat Services failes to start please check the privileges error
but If i remove Database script then it is not throwing any error. I am not able to figure out where i went wrong
2)I am using Apcahe mq in my Application. When I run my Application then a bat file in the Apache mq need to run. So How can I set Custom actions for a bat file to run along with my application.
Please suggest me what configuration should i make to get the right output?
thanks in advance :(
Can you please tell us if you are using a custom action to run the SQL script or our "SQL Scripts" support. Also, the Tomcat server is already installed on target machine? Please keep in mind that you can use our "Tomcat Web Application" template in order to create an installer for a Tomcat web application.
I'm afraid I don't fully understand your scenario. Can you give us more details about this (maybe exemplify)? Also, you can take a look on our "Launch a CMD or BAT file" article.
navya
HI Team,
Thank You for replying ,
I am using java web Application along with Mysql Database and Apache MQ software for message logging. During Packaging my Application I want Apache Mq services to be added with start and stop servies. So I need to add the Apache Service file as custom action.Which means when i install my application Apache mq services need to automatic(Similary like tomcat services). Please let me know how to make the Apache mq services automatic . Its really urgent :(
In order to achieve what you want you can use a service control operation for your ActiveMQ service. Also, you should schedule your install service custom action before "Install Execution Stage -> Add Resources -> StartServices" standard action.
