crairdin
Create shortcut to installed file in 9.6 => hangs
Just trying to create a shortcut to an HTML file in the Application Shortcut Folder. When I select "New Shortcut" -> "Installed File", AI hangs and has to be stopped with Task Manager.
Re: Create shortcut to installed file in 9.6 => hangs
I've tested your scenario, but I cannot reproduce the behavior. Can you attach a sample reproducing this issue or can you send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? Also, can you please tell us what is your machine software configuration?
