bcarswell
Installation failing - 'Doing action: FatalError'
We are experiencing an installation failure on a user's PC and can't determine from the log file at what point the installation is failing. No error is shown to the user, they simply get the 'Setup Wizard ended prematurely' dialog. The target PC is Windows XP and the user performing the installation has full administrative privileges. There was a previous version of our software on this PC which has been uninstalled.
Any help on this is appreciated as we are currently unsure of what we need to look into to get this resolved.
The installation log and aip file are attached.
Thanks in advance.
Brett
Setup-iMeasure.aip
(223.06 KiB) Downloaded 416 times
imeasure.5.2.2.186.log
(707.18 KiB) Downloaded 339 times
Re: Installation failing - 'Doing action: FatalError'
From what I see in your log file the installation process ends with a return value 2, which means that the installation process is canceled by the user. Please take a look on "Logging of Action Return Values" article.
bcarswell
The user says that they are not cancelling anything in the install process. Are you looking at the 6th last line in the file to determine this? This line:
Action ended 8:32:53: FatalError. Return value 2.
In the log file there is a line much earlier:
MSI (c) (40:9C) [08:32:45:328]: Doing action: FatalError
What is causing the fatal error?
I have also attached the dialog that the user is shown when the installer terminates.
FEG iMeasureinstallerror.jpg (25.38 KiB) Viewed 9114 times
Brett
Hello Brett,
I'm not sure why you are encountering this behavior. Can you please try to manually install the related prerequisite packages added in your project and see if they install successfully on target machine?
bcarswell
Hi Daniel,
The application is installed side by side with another which installs correctly with the same prerequisites so I don't think the prerequisites are the problem. Any other ideas?
I see the following line in the log which I assume comes from Advanced Installer. Is this an error?
MSI (c) (40:9C) [08:31:01:453]: Note: 1: 2262 2: AI_AppSearchEx 3: -2147287038
Brett
mihai.petcu
Hi Brett,
As my colleague mentioned this seems to be a prerequisite related issue. Moreover, we can't get anything from the log file except that the user or a process somehow manually stopped the installation.
Can you please check if all prerequisites added to the project are correctly installed in the Control Panel?
bcarswell
We have got to the bottom of this issue. It was due to the PC not having the latest root certificate update from Microsoft. We assume that our driver installation was failing as its signature could not be properly verified.
Cheers,
Brett
