Sangam
how to change path of updater.ini file???
I have one query.During .msi creation i used update.exe which creates
updater.ini in application folder by default but i want to change the path
of updater.ini during .msi creation. Is this possible?????? if yes then how?????
Sangam
Re: how to change path of updater.ini file???
Hi Sangam,
This is not possible. The INI file is strictly related to the updater, you should not try to edit or move it away from the updater.
