mattatkins
Driver upgrade, unsigned to signed
I have been using Advanced Installer to install our device driver alongside the software installation, using the Drivers tab, for the past couple of years and all has been working fine.
Up to now the driver has been unsigned, which means that the warning is popped up by Windows whenever the driver is installed, but now we have just got the driver certified through Microsoft.
The newly created installer now installs without the warning on fresh installations, BUT, when upgrading an existing installation, the warning is still displayed. Surely this shouldn't be the case?
If I upgrade the driver manually in device manager, no warning is displayed, but upgrading through Advanced Installer still generates the warning. This happens on all Windows versions.
This means that all of our existing customers (10000+) will still get the warning displayed when they upgrade.
Is this a known issue? - Can anything be done to resolve?
Cheers,
Matt
Re: Driver upgrade, unsigned to signed
Hello Matt and welcome to Advanced Installer forums,
Can you give us more details about the warning message you are receiving during upgrade (maybe attach a screenshot)?
mattatkins
It's just the standard Windows driver warning:
Windows7:
Win XP:
Can you please add the related certificate file, which you are using to sign the driver package, alongside the driver resources in "Files and Folders" page and see if the behavior still persist?
mattatkins
The driver is signed by Microsoft - the process for getting the driver signed (if you're not aware) is:
Purchase a code signing certificate from Verisign, Verisign check out the company before granting.
Sign a Microsoft supplied executable with this certificate and upload it.
Also sign the driver and upload it.
Microsoft check out the company, certificate, driver etc, and if all ok, they re-sign the driver with their own certificate, and supply the security.cat file.
It then passes the Windows test for a recognised driver, and the warning not displayed on install.
So... Do you mean the security.cat file, or the actual certificate (.cer, .pfx etc)? with or without private key? If the certificate, then our one or the Microsoft one that the driver is signed with?
Cheers
Yes, you should add the related security.cat file and see if the behavior still persist.
mattatkins
The security.cat file is already added.
I'm afraid I'm not sure why you are encountering this behavior. Also, please keep in mind that Advanced Installer uses Windows Driver Install Frameworks (DIFx) to install drivers. This framework is designed for installing Software First Install drivers. These are the drivers that come with your application, e.g. an antivirus filter for the network adapter. It is not recommended to use it for installing Hardware First Install type of drivers, e.g. a driver for your sound card.
