jfuhr
Digital Signature
I purchased a Code Signing Certificate so that we can sign our files and get rid of the "Unverified publisher" message that Windows will display.
In my project, I chose "Use File from Disk" and linked to the certificate and private key. Everything good so far.
When I compile the project, it wants to me to point to the tool used for digital signing. This is where I am stuck, because I purchased the certificate from Comodo, I didn't create it.
Also, this is a Visual Basic 6 EXE and not a .NET, so I didn't sign the exe.
What am I supposed to do now?
James
mihai.petcu
Re: Digital Signature
Hi James,
What Advanced Installer version are you using? Advanced Installer should use the default DigiSign.exe signing utility.
You can read more about signing utilities in the Digital Signature Page article.
jfuhr
8.8.1
I've attached a screenshot of my settings.
mihai.petcu
If you are using any external tools, you should make sure SignTool.exe or SignCode.exe are installed on the development machine. For example, SignCode.exe comes with Microsoft Windows SDK.
This can be done from menu bar -> "Options" -> "External Tools..." -> select a correct path for the utility. If "Use and external tool" option is not enabled, Advanced Installer's DigiSign.exe default tool will be used.
