den
"Windows - No disk" error message
I use Advanced Installer 9.4 Enterprise and everything works well.
I create LZMA-packed multilingual installer for our headliner product with Enhanced UI and bootstrapper.
However recently I've encountered unpleasant issue installing it on the system with MS Windows Server 2003 Enterprise with SP2 installed.
Language selection and prerequisites installation phases were performed as expected, but right after installation began system window appeared (see attachment noDiskError.png). If I press 'Cancel' or 'Continue' installation proceeds. More such windows can appear during installation. After all application get installed correctly.
I've done a lot of internet searching but found nothing useful. After all I've noticed that this issue occurs only if it is preceded by another one.
We install .NET Framework as global prerequisite before installation, after it get installed it asks user for system restart. Sometimes restart button have no effect, system doesn't get restarted and installation begins. It is very strange because we actively use .NET Framework-based executables during installation and everything seems to work fine - except this "No disk" popup. Can you help me work out this issue?
Daniel.
mihai.petcu
Re: "Windows - No disk" error message
Hi Daniel,
Does this behavior manifest on several clean Windows Server 2003 Enterprise with SP2 installed machines?
den
Hi Mihai,
I don't have information about physical machines, but looks like this behaviour manifests only on virtual machine with Windows Server 2003 Enterprise SP2 x86. We have similar virtual machine with Windows Server 2003 Enterprise SP2 x64 and that issue never occured there. However on x64 machine .Net framework installer doesn't require reboot. We use same web installer on both x86 and x64 systems, which can be downloaded from Microsoft here - http://download.microsoft.com/download/ ... _setup.exe.
These virtual machines are controller by Hyper-V and I use them via RDP.
Daniel.
mihai.petcu
Hi Daniel,
No, not necessarily physical machines, I mean to try on other similar machines and see if the behavior persists.
den
Hi Mihai,
Sorry, now I have access only for two Windows Server 2003 virtual machines, both seems to work fine when reverting to last snapshot (clean OS install). Issue manifests on machine with x86 OS regularly (if no actual restart is made after .Net Framework install despite "Restart now" button is always clicked) and never on x64 system, where no restart is needed.
Daniel.
den
Hello, Mihai,
Do you have any ideas about this issue?
Daniel.
mihai.petcu
Sorry Daniel, I didn't respond because is most likely related to that particular machine.
I have a "Windows Server 2003 x86" virtual machine, you can send me a link to the built package at support at adavancedinstaller dot com so we can clarify.
den
Hi, Mihai,
That is OK, I am inclined to think so too.
Daniel.
