prajurk
How to clean up registry after uninstalltion?
I have used Advanced Installer on windows 7 to create a .msi file for my EXE built on VC++;
The Exe saves the registry settings every time it closes;
Now My Problem is when I uninstall and reinstall then my previous settings are appeariong on my EXE
as the old saved regitry settings are taken in the new installation
Can anybody please help me to clean up the existing key vlaues in the registry after uninstallation
I tried to set some default values in the registry settings, but during installations it says you dont have access to change the
default\ ..\settings (please see the image)
mihai.petcu
Re: How to clean up registry after uninstalltion?
Usually, when you need to clean up resources you can use the "Uninstall Cleanup..." wizard available from the Registry page context menu.
