mheckmann
Surface Theme problem with checklist cntrol
I'm trying to use the surface theme but came about this problem:
You can't see the checkboxes if they are not selected. Is there something I can set to change that?
Also one other question would be that window titles seem to be gone. Is there a way to add them manually?
Thx
Markus
Re: Surface Theme problem with checklist cntrol
Hello Markus,
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
You cannot achieve this. Please keep in mind this is the normal behavior for "Surface" theme.
mheckmann
Hi Daniel,
is there a chance for this to be fixed in a upcoming release or is it lower priority and I should look at using a different theme?
thx
Markus
Hello Markus,
A fix for this issue will be included in version 9.9 of Advanced Installer which will be released in the first few months of the next year.
This was fixed in version 9.9 of Advanced Installer released on February 04, 2013.
