We have some customers using a .msi produced by Advanced Installer 4.8.1 that are running into an "Installer Information" alert which states:
"The specified path is too long: C:\ProgramData\Documents\Neon Software".
The problem seems to occur when running the installer on a Vista machine that has been upgraded from an XP machine. It may have something to do with the folders in question being symlinked but that's just a theory.
I do see a forum message discussing a similar problem that occurs as the result of a substituted drive, but I don't belive the conditions are the same as we are encountering:
http://www.advancedinstaller.com/forums ... +path+long
Is there some explanation or workaround for this problem or perhaps more information we can provide that will help diagnose the problem?
Michael Swan
Neon Software, Inc.
Here is a snippet from the installer log file where the problem occurs:
1: {81F9D463-3B8B-40F2-BC9D-9F301532336F} 2: {EE276E83-0167-48B8-9CBF-794B34FAAD9D} 3: C:\ProgramData\Documents\Neon Software\LANsurveyor\Recovered Files\
Action 18:46:29: RemoveODBC. Removing ODBC components
Action 18:46:29: CreateFolders. Creating folders
CreateFolders: Folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LANsurveyor\
CreateFolders: Folder: C:\Program Files\LANsurveyor\Neon Responder Updaters\
CreateFolders: Folder: C:\ProgramData\Documents\Neon Software\LANsurveyor\
Error 1320. The specified path is too long: C:\ProgramData\Documents\Neon Software
MSI (s) (5C:00) [18:46:34:698]: Product: LANsurveyor -- Error 1320. The specified path is too long: C:\ProgramData\Documents\Neon Software
Are you sure you want to cancel?
MSI (s) (5C:00) [18:46:37:219]: Product: LANsurveyor -- Error 1320. The specified path is too long: C:\ProgramData\Documents\Neon Software
Action ended 18:46:38: InstallFinalize. Return value 2.
Action 18:46:38: Rollback. Rolling back action:
