tropez
User being prompted about Interactive Services Detection
So I built an installer that does a few things.
1. It installs a font.
2. It sets some .NET security parameters by running CASPOL 4 times for our 4 different sites we have to configure ([CASPOL] -m -rg "STARLIMS starlimsdev")
3. It adds some IT favorites.
During the installation (which I'm pushing using vCenter Protect using /quiet) users are getting prompted with a message, see attachment. Users get the warning, and if they click Yes they see "a message in a command prompt window saying: The operation you are performing will alter security policy. Are you sure you want to perform this operation? (Yes/No)". They get this multiple times, so I'm assuming each of these CASPOL executions are causing this.
How do I suppress this? It's throwing a huge wrench in our patch cycle this month.
message on install.jpg (53.36 KiB) Viewed 3698 times
tropez
Re: User being prompted about Interactive Services Detection
My end user reports "It just came back up and I answered yes 2 more times (which is a total of 4) and it stated the program didn’t require any more attention…so I believe I’m good now…"
So it is the CASPOL execution....
You can try using the "-quiet" parameter for CASPOL.
