I'm afraid we don't have a predefined functionality for this. However, you can use a
custom action in order to achieve what you want (e.g. you can create your own custom action which will read from file and store the result in a
property (e.g. MY_PROP)). Also, the custom action should be added before "Paths Resolution" action group. Then, you can create in
"Files and Folders" page a property based folder using MY_PROP property.
You can take a look on our
"How could I read an "external" .INI file?" which may be helpful for you.
Also, if you want you can set the related path in an XML file and use our
"XML Search" Enterprise feature.
Let us know if this helped.
