santoshinstaller
Installation on 64 bit OS
When I try to install the executable on 64 bit OS then it shows me error. I am trying to install a wb application.
Can you please help?
Santosh
Installation Error.GIF (72.24 KiB) Viewed 1922 times
Installation Error2.GIF (5.74 KiB) Viewed 1922 times
Re: Installation on 64 bit OS
Hello Santosh,
You are encountering this behavior during IIS configuration because Advanced Installer IIS tool requires some IIS components that are not installed on target machine. As a workaround you can perform the following steps on target machine:
- Go to "Control Panel" and open the "Turn Windows features on and off" applet.
- Go to "Internet Information Services".
- Select "Web Management Tools".
- Check all options under it.
These steps should enable all IIS components required by an installation.
