Ohm
JRE not found
Hi everybody,
new to this forum and breaking my head with the same kind of problem than in this topic :
http://www.advancedinstaller.com/forums ... =2&t=10264
evreything goes fine except that when I launch the installed app I have this message saying that there's no JRE (but yes !!!), and even if I browse to the jre, the OK buton stays grey :-(
I'm on windows 7 64 bits.
the jre 1.7 is installed in program files (x86) which is normal because of the Internet browser in 32bits (Chrome, Firefox...)
I can make the app launch if I manually install a 64bits JRE 1.7 (which goes in Program files).
but this is not an option for "lambda" users...
so is this a bug ? or did I miss something in the config ?
Thx for any help :-)
Ohm
Re: JRE not found
anybody ? is this a dummy question ?
Re: JRE not found
I'm not sure why you are encountering this behavior. Can you please tell us what is the type and platform of your java launcher created in Java Products page? Also, can you send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it?
