capeuk
Installer only shows English prompts
When I run my AI installer in Spanish Windows, it still show phrases in English. I expect it to automatically speak in Spanish. What am i doing wrong?
capeuk
Re: Installer only shows English prompts
Hello Capeuk,
In order to achieve what you want you can use the "Automatically use system language for installation" option from "Translations -> Languages" tab.
Let us know if this helps, otherwise please give us more details about your scenario (maybe exemplify).
capeuk
Hi Daniel,
lang tab.jpg (314.96 KiB) Viewed 8510 times
Included is my translations, Language tab and i can't see "Automatically use system language for installation". Am i missing something. Please note that i am using version 8.1.3 Enterprise, see my licence below.
capeuk
my licence.jpg (79.75 KiB) Viewed 8510 times
Hello Capeuk,
Please keep in mind this is the standard Windows Installer behavior if the target machine have installed the Spanish language pack for system user interface, but the related target machine system language is still English. The installation package will use the Spanish language only when the Windows system language is Spanish, not when you have installed the Spanish language pack for system user interface.
However, in order to achieve what you want you can proceed like this:
- Go to "Media -> Bootstrapper" tab and enable create "Create EXE setup file" option.
- From the "User Interface" group select "Display language selection dialog (for multi-language packages)" option.
- Build and run your project.
In this way you will have an EXE installation package which displays a language selection dialog.
Let us know if this helped.
capeuk
Hi Daniel,
Thanks for your reply.
I am already creating a EXE installer. I understand that the installer would display according to Windows system language. The Windows in question wasn't mine but a business agent partner who works in Spanish, see screen attached.
The last bit of your advise, i can't follow. "User Interface" group - OKAY.
"select "Display language selection dialog (for multi-language packages)" option" where is this. Under user interface group i have themes, translations, slideshows and Dialog. Could you elaborate further with screen shots.
advanced installer.jpg (217.08 KiB) Viewed 8497 times
Hello Capeuk,
I apologize for my confusing response.
I mean you should enable the "Display language selection dialog (for multi-language packages)" option from "Media page -> Bootstrapper tab -> User Interface" group.
capeuk
Hi Daniel,
Yes, my setting was on target language. I will test.
Question:
What is the difference between "target system language for installation" and "current user language for installation". The help file wasn't clear enough.
capeuk
Hi Daniel,
Switching Deployment group Media\Bootstrapper "User Interface" to "Automatically use current user for installation" solved my problem.
Many many thnaks. :D
capeuk.
Hello Capeuk,
When you enable the "Automatically use system language for installation" option, then the package installation will use the system language set during system installation on target machine. Also, when
the "Automatically use current user language for installation" option is enabled, then the package installation will use the language configured for the current user.
