ttega
Installer not ending on XP SP3 VM
I have just updated AI to 9.7 and I noticed that my installer does not complete on a (Japanese) XP x86 SP3 virtual machine.
As shown in the attached PNG, the "Finish" button is disabled and it doesn't change no matter how long I wait for.
I think it was working fine in the previous version 9.6.1.
I executed the same installer on English Vista x86 VM and Japanese Windows 7 x64, but no problem was observed on these platforms.
Any help would be appreciated. Also let me know if you need more information to reproduce the problem.
Best,
Toshiyuki
ttega
Re: Installer not ending on XP SP3 VM
I have reverted AI to 9.6.1 and found that the problem still occurs in 9.6.1 as well.
So it may not be something peculiar to 9.7.
The "Finish" button is enabled at first when the wizard page is shown, but turns to disabled state in a second.
I'm not sure why you are encountering this behavior. This may be related to a files extraction issue. Starting with version 9.6.1 of Advanced Installer we have updated our old files extraction method with a new one (some improvements to the extraction support have been added to speed up the installation and provide a better UX during the install, but unfortunately some bugs have been included along with these improvements). Can you set the property "ExtractFilesFirst" to value "1" in Install Parameters page (in this way the old files extraction method will be used) like this:
  • Name: ExtractFilesFirst
    Value: 1
and tell us if the behavior still persist?
ttega
Daniel,
Thanks for your support.
I tried setting ExtractFilesFirst to 1 as you described, but the behavior is the same.
It still disables the button immediately, right after it moves onto the last wizard page.
Hello Toshiyuki,
Unfortunately, currently we don't have a Windows XP Japanese machine so we can test your scenario. Therefore, please give us some time to investigate and we'll get back to you as soon as we have a conclusive answer.
Also, can you please send us the .AIP (project file) and a detailed step by step test case scenario to support at advancedinstaller dot com so we can try to reproduce the behavior and investigate it?
ttega
Daniel,
Thank you for your prompt response.
As I add and remove a few files to the project, the problem went away somehow.
I wasn't really touching any options which may affect this, but it is working fine now for some reason.
In case it starts occurring again, I will send .AIP and such as you have suggested.
Thank you,
Toshiyuki
