neoswarm
Upgrade tab - not removing old product
I have a professional copy of advanced installer 9.7, on windows 7 x64 and for the life of me cannot remove the old program that exists on my machine (attached is a screenshot and my setup.aip)
When I run, the log says:
MSI (s) (F0:D8) [14:31:05:851]: Skipping action: AI_PREPARE_UPGRADE (condition is false)
The upgrade code was captured by Advanced Installer’s auto detection software….and is installed on my machine. (even double checked upgrade code)
(sidebar: I can run the custom action: msiexec.exe \x {product code} and it will run fine. However, I do not want it to run when the program is already installed).
ANY suggestions/solutions would be GREATLY appreciated…
Thanks!
Mike
p.s....i can give you the install file of the old program for testing if neccessary. It's an outlook plugin
setup.aip
aip setup file
(30.88 KiB) Downloaded 566 times
Re: Upgrade tab - not removing old product
Hello Mike and welcome to Advanced Installer forums,
Please keep in mind that a per-user installation cannot upgrade a per-machine installation and a per-machine installation cannot upgrade a per-user installation. So, please make sure that your upgraded and upgrading installation package have same installation type (both of them should be installed per-user or per-machine).
Also, as a side note, please do not duplicate a question on the forums if you have already sent us an e-mail with it. Both communication channels have the same priority to us, therefore posting the question in both places doesn't really help.
neoswarm
Thanks Daniel!
You're welcome. Glad to help.
