b.biene
CAB-Errors
I have a setup-project with 3 diffrent outputs.
First output is a EXE (mixed 64bit/32bit) including all resources
Second output is a MSI 64bit including all resources
Third output is a MSI 32bit including all resources.
If i make a rebuild of the entire project i get all outputs.
But every time one of the the setup-packages is defekt. Every time a diffrent one.
Somtimes i get a error with the EXE installer. I make a rebuild, EXE works but the x64 MSI is failing.
Rebuilding x64 works and 32bit MSI fails. And so on.
See the error attached.
I have the newes version from AI (9.7).
Signing is activated for the installer.
I have a bit too much bugs for a software i paid $1,000!! :evil:
Re: CAB-Errors
I'm not sure why you are encountering this behavior. Can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it?
b.biene
Re: CAB-Errors
after disabeling the output-cach i got the first time one build where all outputs worked!
Re: CAB-Errors
Can you enable the caching option again (after you have disabled it), build your project and tell us if the behavior still persist?
b.biene
Re: CAB-Errors
Sorry i can't.
I'm happy that it's working now.
b.biene
Re: CAB-Errors
It's realy anoying.
And the error is there again!
b.biene
Re: CAB-Errors
Something i can do
Re: CAB-Errors
Can you please tell us if the related error appears only when you have the caching option enabled? If so, can you please disable (and build) and then enable the caching option and see if the behavior still persist?
Also, since you have a quite complex project it will be difficult for us to find out what is the root cause of this issue. So, can you please try to create a sample test project which reproduces this issue and send us to investigate it?
b.biene
Re: CAB-Errors
Error it ther now with caching disabled.
I have the same output dir for all my outputs. Is this perhaps a problem?
Re: CAB-Errors
It may be a possible cause. Can you set different output locations for all builds and see if the behavior still persist? If so, can you please try to to create a sample test project which reproduces the behavior and send it us to investigate?
b.biene
Re: CAB-Errors
What do you think is the reason i spend $1,000 for an installer?
Correct, i want to save time. And not reproduce every of bug you have in your software.
I've send you my Project-File. That should be enough.
b.biene
Re: CAB-Errors
It's a desaster!
Error there again!
Changed nothing...!
Re: CAB-Errors
First of all I apologize for this inconvenient. Can you please send us your .AIP (project file) and all the resource files used by your project to build the installation packages to support at advancedinstaller dot com so we can try to reproduce and investigate this issue?
