b.biene
Read-Only flag on Folders
Why is AI setting the readonly attribute on folders creating upon install?
I'm not able to diable this behavior?!
See image:
Re: Read-Only flag on Folders
Please take a look on our "Read only installation directory on Windows 7" article which may be helpful for you.
b.biene
No.
It's not a user-right problem.
Application is impersonating Addminstrations right.
The problem is, as i said that the Read-Only flag is set by AI.
I ported my Installer vom VS2008. The Setup with the "old"-isntaller on the same system wil not set the "read-only" flag.
Btw.: the screenshot is from a WinXP-VM
I'm not sure why you are encountering this behavior. Can you attach a sample project which reproduces the behavior so we can investigate it? Also, can you give us a detailed step by step test case scenario so we can try to reproduce and investigate the behavior?
b.biene
You already got the AIP file via e-mail.
It was because a diffrent issue.
See:
http://www.advancedinstaller.com/forums ... =2&t=23026
I've tested your scenario, but I cannot reproduce the behavior. Can you reproduce the behavior on multiple clean machines? If so, can you give us a detailed step by step test case scenario so we can try to reproduce and investigate the behavior? Also, can you send us a verbose log of the installation to support at advancedinstaller dot com so we can investigate it?
