valiot
Product Version auto-populated from application version
I would like the Product Version field to get auto-populated from my application executable version. Is this possible?
Re: Product Version auto-populated from application version
If you don't want to manually change the product version you can use our "Command Line" support. You can write your own script or BAT file which will set the "ProductVersion" property of your project and then will build your project.
