bchetana
Invoking updater from c# application
Hi
I am trying to install upgrades for my application using a menu in main form c#.
On the click event I am calling "SWUpdater.exe/checknow" for installing the updates. But while installing the updates I am getting following error message .. How to avoid this???
Re: Invoking updater from c# application
In order to avoid the "File in Use" dialog you can use one of the following two solutions:
1. Create a "Close Application" custom action for each application you want to close.
OR
2. Use the "Auto Close Application" feature when you create the Updates Configuration File.
