rtischer8277
Launch file as Administrator does not work
I have made a custom action that launches my installed executable with administror privileges. Here is the setting:
runasadmin does not work.png (24.9 KiB) Viewed 2323 times
The executable does not, however, launch with admin privileges. What is the problem?
Re: Launch file as Administrator does not work
Please keep in mind that the package installation files are deployed on target machine after "Install Execution Stage -> Add Resources" action group. So, you cannot launch the related installation file using a custom action without sequence (e.g. Launch file as Administrator). In order to achieve what you want you should add the related EXE file as a temporary file to your project.
Also, you can take a look on our "Launch a CMD or BAT file" article which may be helpful for you.
