codemonk3y
set App Pool settings
In the Application Pool for our websites we want to change the idle time-out from the default, but I'm not sure where I can set it at. On the IIS page I can see the app pools we have, but there is no place to change any of the advanced app pool settings. Do I need to create a custom action just to set these?
Scott
Re: set App Pool settings
Hello Scott,
In order to achieve what you want you can set the "Shutdown worker processes after being idle for:" field from "IIS -> Application Pool -> Performance" tab.
