jusher
Select more than one SQL script for deletion
I can only select 1 SQL script for deletion in SQL Scripts, connections. Any plans to change this?
John
Re: Select more than one SQL script for deletion
Hi John,
No requests regarding this support were received so far. Do you have a scenario were multiple selection would be required?
jusher
Yes, same as Windows Explorer. Instead of deleting one file then refreshing the screen it should allow multiple deletion.
Another thing on the same page. If you add a new sql script it places it at the bottom of the page, so you then have to place it. If you have more than one page of stored procedures when you press the CTRL sequence to move it in the list the page does not automatically scroll so I have to drop the stored procedure into a higher position and then repeat the control sequence to move it higher in the list.
Reagards,
John
jusher
Was this ever fixed?
Hello John,
I have done some tests and it looks like the answer is, unfortunately, no.
I will add this on our TODO list of improvements now and it will be added in a future version of Advanced Installer (will do my best so that is asap).
I will update this thread as soon as this improvement will be added.
This improvement has been added in version 20.7 of Advanced Installer, released on May 25th, 2023.
Return to “Feature Requests”
