shetty_rohan
Multilingual support query
hi,
I have supported multilingual support as explained in http://www.advancedinstaller.com/user-g ... ement.html.
I am currently using the following xml file(as dictionary)
  <ENTRY id="AgreementText">
    <STRING lang="en" value="C:\My Installation Project\EULA English.rtf"/>
    <STRING lang="fr" value="EULA French.rtf"/>
    <STRING lang="de" value="EULA German.rtf"/>
  </ENTRY>
This works fine in most of the cases except one case/
Problem: For English language if I change the path in the xml file, it does not work. But, if I change path in the xml file for "french" language it works fine.
For English, it is required to change in the properties of the LicenseAgreementdlg(i.e Open the LicenseAgreementDlg, Click on the scrollable test, click on RTF file, and then change). Is it possible to do the same through xml file(i.e dictionary file)?
Re: Multilingual support query
Please keep in mind that this is the normal behavior. The path you set in the "LicenseAgreementDlg" dialog cannot be changed from the XML file.
The path you choose in the "LicenseAgreementDlg" dialog is included in the XML file as an indication of what you have to write for the other languages.
shetty_rohan
@Eusebiu:Thank you for the clarification
You're welcome. Glad to help.
