shetty_rohan
Question:Multilingual package installations
I have supported two languages in my product(en and de). I have used the setting "create separate packages", because of this Advanced Installer generates different packages(i.e one for English and the other for German).
Now I install the English version. After this I can again install the German version of the product. This would create the problem in my Product.
Question: Suppose if the user already has the product in one language, he should not be allowed to install the same product(in some other language). Can I do this by having the same "ProductCode" for all the languages? Is this the right solution??
Re: Question:Multilingual package installations
Hi Rohan,
Using the same "Product Code" for all the languages is a solution.
Also, you can achieve this by following the next steps:
- go in the Search page
- create two "Product Version (identify by Product Code)" extended searches (i.e. ENG for English package and GER for German package)
- go in the "Custom" tab from the Launch Conditions page
- create two new custom launch conditions like in the example below:
  • Condition: ENG = ""
    Description: English is installed
    Condition: GER = ""
    Description: German is installed
Build and run the project.
shetty_rohan
Thank you Eusebiu, Your solution is working fine :-)
shetty_rohan
Two short question related to this
1) in case(1) i.e Setting the same "Product Code" for every language
- do I need to change this for every upgrade(i.e Generally when we change the Product version number, product code also gets changed, so do I need to manually set the same code for every language for every upgrade)?
2) in case(2) i.e support by search(as you had suggested)
- do I need to change the contents of the search for every upgrade(i.e Generally when we change the Product version number, product code also gets changed, so do I need to manually place the product code in the search for every upgrade)?
Unfortunately you have to make those changes in both cases.
shetty_rohan
Thanks for the response
