I was testing a new build of our s/w and ran into a config issue with IIS, the install was built with AI 9.7 (cant upgrade atm), this particular virtual directory has been present in out builds for some time, so im not sure what the issue is, any ideas?
I checked the IIS and can see that it hasnt created the "ApertaLicensingService" vdir, and confirmed i was manually able to create it without error - this is on 2008 server OS
AI_IIsConfig: Installing "ApertaAppPool"
AI_IIsConfig: Installing "DocArchTest/ApertaWebEssentials"
AI_IIsConfig: Installing "DocArchTest/DocumentArchive"
AI_IIsConfig: Installing "DocArchTest/ig_common" AI_IIsConfig: Installing "DocArchTest/ApertaWebEssentials/ApertaLicensingService"
Error 4020. There was an error during the IIS configuration process.
Your original IIS configuration will be restored.
MSI (s) (1C!9C) [13:32:38:443]: Product: Aperta Document Archive -- Error 4020. There was an error during the IIS configuration process.
CustomAction AI_IIsConfig returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 13:32:38: InstallFinalize. Return value 3.
MSI (s) (1C:24) [13:32:38:466]: User policy value 'DisableRollback' is 0
I have an installation which is supposed to work only on 32 bit machines, when I execute this on 64 bit machine I get the following error
"This installation package is not supported by this processor type. Contact your product vendor" with the caption as "Advanced Installer"
Is it possible to customize this message text and caption??
@: FergusMurray : You may encounter this behavior due to a recent bug in Advanced Installer. Please give us some time to investigate and we'll get back to you as soon as we have a conclusive answer.
@: johny3329 : Please take a look on our "Customized error while checking for the processor type" thread which debates this issue.
Also, as a side note, please do not post on a thread which doesn't debate a similar topic with you issue.
Thanks Daniel, if there is a patch I can use for 9.7 (unfortuately cant use 9.8 due to issue with IIS passwords) would it be possible to send it, i need to make a build of our software this week to send to some customers
In order to get more details about what happens can you download the following debug DLL, replace the original one from the install folder of Advanced Installer (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 9.8\custact\x86) on your machine and rebuild the package.
Just replace the original iis.dll from the install folder of Advanced Installer with this one, then restart the application and rebuild the package. This DLL should create a debug log (at install time) on the root of the OS partition (e.g. C:\AI_IIS.log), which can give us more details about the problem. So, can you send us the AI_IIS.log file, to support at advancedinstaller dot com, after you will build and test your installation package using the debug iis.dll?
The build created with the debug version does not have any error and the application is installled without error
Have sent the log to support, in case there is anything helpful in there
Can you test your installation package on multiple clean machines with IIS 7 installed (e.g. Windows Server 2008) and see if the installation succeeds? If not, can you send us the debug log file (AI_IIS.log) to support at advancedinstaller dot com so we can investigate it?
have tried the installed (with the debug iis.dll) on 3 separate IIS7 win 2008 setups, none of which fail, does that mean i can get a non-debug version to get our build out?
Can you build your installation package using the following release dll (which contains some fixed issues), then test it on the related system target and see if the behavior still persist?
I'm getting this error now too. Below is part of the log. I was using version 9.4 and just installed 10.0. I did not uninstall 9.4 b/c that's what our old installers are in and we have not had time to make sure everything works in 10. Is there still an issue with the iis.dll or is my 10 using the 9.4 version? If I use the dll from above should it fix my issue? I thought this would be fixed now in versino 10.
Scott
Action start 9:48:42: InstallFinalize.
MSI (s) (A8:D8) [09:48:42:408]: Running Script: C:\WINDOWS\Installer\MSI1CF7.tmp
MSI (s) (A8:D8) [09:48:42:408]: User policy value 'DisableRollback' is 0
MSI (s) (A8:D8) [09:48:42:408]: Machine policy value 'DisableRollback' is 0
MSI (s) (A8:D8) [09:48:42:408]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1115377174,LangId=1033,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
MSI (s) (A8:D8) [09:48:42:408]: Executing op: ProductInfo(ProductKey={DB6D2F10-E36F-40A6-8BDF-59A4AF427039},ProductName=MyAppDeploymentServices,PackageName=MyAppDeploymentSite.msi,Language=1033,Version=218171552,Assignment=1,ObsoleteArg=0,,,PackageCode={E13E8875-6D99-4D9C-8B23-2F7D2F2D42CF},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3)
MSI (s) (A8:D8) [09:48:42:408]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (A8:D8) [09:48:42:408]: Executing op: DialogInfo(Type=1,Argument=MyAppDeploymentServices)
MSI (s) (A8:D8) [09:48:42:408]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,,CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (A8:D8) [09:48:42:408]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (A8:D8) [09:48:42:408]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (A8:D8) [09:48:42:408]: Executing op: ActionStart(Name=AI_IIsRollback,Description=Rolling back IIS configuration,Template=Restoring metabase configuration.)
Action 9:48:42: AI_IIsRollback. Rolling back IIS configuration
MSI (s) (A8:D8) [09:48:42:408]: Executing op: CustomActionSchedule(Action=AI_IIsRollback,ActionType=11521,Source=BinaryData,Target=**********,CustomActionData=**********)
MSI (s) (A8:D8) [09:48:42:423]: Executing op: ActionStart(Name=AI_IIsConfig,Description=Configuring Internet Information Services,Template=Installing "[1]")
Action 9:48:42: AI_IIsConfig. Configuring Internet Information Services
MSI (s) (A8:D8) [09:48:42:423]: Executing op: CustomActionSchedule(Action=AI_IIsConfig,ActionType=11265,Source=BinaryData,Target=**********,CustomActionData=**********)
MSI (s) (A8:10) [09:48:42:423]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI1D18.tmp, Entrypoint: OnIIsConfig
AI_IIsConfig: Installing ""
MSI (s) (A8!0C) [09:48:45:861]: Product: MyAppDeploymentServices -- Error 4020. There was an error during the IIS configuration process.
Action ended 9:48:45: InstallFinalize. Return value 3.
I sent a copy of my log and aip file to the support email.
I think I found the problem, but not sure why. In the IIS page, for my website, on the https/ssl tab it does not like when I use a property for the Thumbprint (hash). I am using custom actions to change the thumbprint value depending on which region is being installed. In the UI it resolves the value correctly, but why doesn't the install work when the property is used?
I made a trimmed down aip (with only 1 region and no custom actions) to try and figure out the problem. This is how I figured out it's the thumbpring and here's the part of the log now, the error's a little different.
MSI (s) (D4:88) [23:30:23:951]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIDE15.tmp, Entrypoint: OnIIsConfig
AI_IIsConfig: Installing "MyApp-Future"
Error 4031. There was an error while processing the digital certificate for Web Site "MyApp-Future".
MSI (s) (D4!7C) [23:30:28:868]: Product: MyAppClientDeploymentServicesFuture -- Error 4031. There was an error while processing the digital certificate for Web Site "MyApp-Future".
MSI (s) (D4!7C) [23:30:29:492]: Product: MyAppClientDeploymentServicesFuture -- Error 4020. There was an error during the IIS configuration process.
Action ended 23:30:29: InstallFinalize. Return value 3.
