narasimhakashyap
Missing References
I tried to build the Setup file from the Advanced Installer. On my client machine, if visual studio is not installed an error is thrown as below:
Could not load file or assembly 'Microsoft.Windows.Design, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
But, for the same project, I built the setup file from the Setup project from Visual Studio and it works fine.
There might be some missing references which I'm not able to find out.
Any help??
Thanks in advance
Re: Missing References
I'm not sure why you encounter this behavior. Can you please send us the .AIP (project file) and a screenshot with the error so we can investigate the problem?
narasimhakashyap
I found that I was missing some output dll's while building the setup. And which is why the error.
Thanks for the support.
And sorry for the trouble.
You're welcome. No problem.
