shetty_rohan
Problem in selecting the Build - "Launch conditions"
I have two builds
1) Build1: in which I have checked "Launch condition" -> Software -> "Java runtime environment"-> JRE 1.6
2) Build2
Now, in build2 if I select the "Launch condition" -> Software -> "Java runtime environment"-> JRE 1.6, it never gets saved. any idea to fix this??
shetty_rohan
Re: Problem in selecting the Build - "Launch conditions"
I have mailed('support@advancedinstaller.com', subject: 'Problem in selecting the Build - "Launch conditions"') you the aip for a sample, in which I have this problem. This mail also contains the exact reproduction steps.
do let me know if you need any help.
Unfortunately, this behavior is caused by a recent bug in Advanced Installer. We are aware of it and it will be fixed in the next version of Advanced Installer which will be released soon.
shetty_rohan
Thanks Daniel. I will wait for the fix.
Until then, as a workaround, you can proceed like this:
- Go to "Launch Conditions -> Custom" tab and add a custom launch condition like this:
  • Condition: AI_JREVERFOUND = 1
    Description: [ProductName] cannot be installed on systems with JRE version lower than 1.6
    Builds: <All Builds>
- Go to "Table Editor" page and in the "CustomAction" table add the following new row:
  • Action: AI_DetectJRE
    Type: 1
    Source: aicustact.dll
    Target: RequiredJreExists
    Extended Type:
- In the "InstallExecuteSequence" table add the following row:
    Condition: 1
    Sequence: 399
- In the "InstallUISequence" table add the following row:
    Condition: 1
    Sequence: 399
- Build and run your project.
Please keep in mind that our "Table Editor" feature is available only in an "Enterprise" or higher project type.
Also, I've attached a sample project, created with version 9.8 of Advanced Installer, which implements this workaround.
sample.zip
(2.61 KiB) Downloaded 391 times
shetty_rohan
Thanks, its working fine.
You're welcome. Glad to help.
