qwertyuiop
fatal error while uninstallation
I have created EXE and installed it.but while uninstalling the EXE from add or remove program of control panel it shows error message as Fatal error but the exe get uninstall from add or remove program .Here with i have attached the screen shot of the error message.
Re: fatal error while uninstallation
This is a generic error message appearing when a custom action fails.
Try to create a verbose log to see which custom action fails and start debugging it.
