shetty_rohan
Mixing the per-machine and per-user features
Question: Is it possible to mix per-machine feature and per-user feature in one installer?
In my installer, I need to support two features
1) Telephony Service Provider(TSP) : This needs to be installed as the per-machine. This limitation is because of the Microsoft, which expects the TSP to be installed as per-machine(because it stores the registry keys in HKLM).
2) Softphone: this needs to be installed as the per-user
Do let me know if you need any clarifications.
Re: Mixing the per-machine and per-user features
In order to achieve what you want, you can create Softphone package per-user and add TSP as prerequisite in this package.
So, when an user will install your application, it will also install TSP prerequisite per-machine, then when another user will install the application, he will no longer need to install the TSP application again (because it was installed per-machine), he will install only Softphone application which is per-user.
shetty_rohan
Thank you, great solution :-)
You're welcome. Glad to help.
