qwertyuiop
dialog box appears while un installtion
I have created the application using installer ,when i try to remove my application from add or remove program it shows some dialog box to continue further.There shouldn't be any user interface in add or remove program.Currently i am using windows 7 OS .These dialog box shows only in 64 bit machine,in 32bit machine it doesn't show any dialog box while un- installation.if there is any option to hide the dialog box in 64 bit using installer.
Here with i have attached the JPEG image for your reference.
Re: dialog box appears while un installtion
That dialog appears to inform the user that the "Java(TM) Platform SE binary" application should be closed before the uninstallation continues. This happens because a part of your application uses some resources from the program specified in the dialog when running on Windows 7 64-bit.
So, you must verify your application to see what is the problem and how you can avoid it.
You're welcome. My pleasure.
