Hello Brian and welcome to Advanced Installer forums,
For the prerequisites, is there any way to get them to install silently or without user intervention?
If you want to have a silent prerequisite installation, then you can configure it to run in silent mode by editing the install command lines from "Prerequisites ->
Setup Files" tab. For an MSI prerequisite package you can use the
/qn command line parameters. Also, in order to silently run your prerequisites packages you should search the corresponding command line parameters on your prerequisites packages documentation.
Let's say Adobe Acrobat X is a prereq, can I get it to install during my main installation without having the user press "Install" when Acrobat prompts them?
In order to achieve this you can add our "Adobe Reader X"
predefined prerequisite package to your main project. Then, you can use in the install command lines fields, from "Prerequisites -> Setup Files", the following command line parameters:
