valiot
Error Applying security settings on French installation
I get the following error trying to install my app:
Here is what I'm doing on a folder in my Files and Folders section:
Should I be using the numeric form instead? S-1-5-11?
Re: Error Applying security settings on French installation
In Windows Installer only Everyone and Administrators are the same for all languages and all other account names should be localized. Advanced Installer localizes these groups and stores their values in properties. You can see more details in the "How do I localize user or group accounts" FAQ.
In the following article it is explained the method we used to localize them.
Just use the property associated to the desired group instead of the exact English name in the package.
valiot
So how do I get the Authenticated Users localized name? I don't see a property for this.
valiot
I decided to try using icacls. This is how I'm running it from the AI interface for custom action. Is this correct?
Running it just before InstallFinalize.
Uncheck "Uninstall" and "Maintenance", so it runs only on install. Also, if the custom action still does not work, try to set deferred with no impersonation.
valiot
I decided to use the Everyone username to avoid this problem all together. I don't have time to figure it out. I suggest you include Authenticated Users as a localized account to make it easier in the future.
GlenT
As noted in my other post, it appears that it is no longer guaranteed that Everyone and Administrators are "the same in all versions of Windows". In the French version of Windows 7 Pro, "Administrators" is "Administrateurs". Not sure yet about "Everyone" (I have asked my client).
P.S. There may be a difference between the recognition of "Administrator" and "Administrators".
Fulgan
FYI, all names are translated into each Windows version. That is why the correct way to reference well-known security principals is to use their SIDs.
