shetty_rohan
Pin the application to task bar
Is there a way to pin the "application shortcut" to the task bar in windows 7 operating system like http://www.codeproject.com/Articles/185 ... ar-on-Win7?
If the question is not clear please let em know, I could explain this along with the steps.
Re: Pin the application to task bar
Hi Rohan,
The Windows 7 taskbar is designed to be configured by the user. Therefore, it is not recommended to pin application on it through installers.
The options that can be set for a shortcut through Advanced Installer are described in the Shortcut Properties Dialog article.
Although, you can achieve what you want by using the "Pin to Taskbar" script code found in the link mentioned by you.
shetty_rohan
Thanks for your response
My pleasure.
