atulthummar
Getting Error on Patch Installs
I am getting error when trying to install patch, please find the attached screens. Also, I am strange after click on ignore it successful completes but when i am actual review the installation folder it wan't have updated files.
please help me on this.
Atul
Re: Getting Error on Patch Installs
Hi Atul,
This error dialog is usually displayed when some of the Creating Patches rules are missed. Please verify them again and make sure no rule is missed.
Also, please try to see if you encounter the same behavior on multiple clean machines.
If the problem persist, can you please send us all three .AIP (project files) so we can investigate them?
atulthummar
I have resolved this issues after clean the images of patch, but finding below issues.
I got successfully installed PATCH on "WINDOWS 7" machine, when i am trying to install same PATCH on "WINDOWS XP SP3" it throws error after finish screen, but it also install new change files and change registry entries as in patch.
please see the attach screens for more info.
1.JPG : It shows Patch has been successfully installed, I have click on "Finish"
2.JPG : This dialog show restart message,I have tried with both NO & YES.
3.JPG : This Shows actual errors. (WHY this shows eroor, but patch is already successfully installed)
Please help me on this
I have tried with different machine and came to know that this issues only occurred in 32 bit OS.
Atul
This article explains we do you get the message and should you fix the problem.
atulthummar
Resolved
Atul
