N\sy
I have a problem with a CA in a feature installation.
I have a double feature in my installation.
First: Feature Management
  • Management.exe
Second: Feature Service. <- Not selected
  • Service.exe
  • ServiceInstall.cmd
  • ServiceUninstall.cmd
Install.cmd is called in a CA when the feature service is selected. But really should not be called when only the feature management was selected.
Exactly what is happening. How can I make within the installation, the CA will be called only if the corresponding feature will be installed!
Extract from the log.
MSI (s) (48:CC) [11:26:21:682]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is '48bd67a975a385429669b2727402dcf3'.
MSI (s) (48:CC) [11:26:21:682]: Feature: Management; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (48:CC) [11:26:21:682]: Feature: NET_Framework_4.0; Installed: Absent;   Request: Null;   Action: Null		//<-- Not selected
MSI (s) (48:CC) [11:26:21:682]: Feature: Service; Installed: Absent;   Request: Null;   Action: Null				//<-- Not selected
MSI (s) (48:CC) [11:26:21:682]: Feature: Management; Installed: Absent;   Request: Local;   Action: Local			//<-- Selected
MSI (s) (48:CC) [11:26:21:682]: Component: ProductCode; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (48:CC) [11:26:21:682]: Component: AppPath; Installed: Absent;   Request: Local;   Action: Local
MSI (s) (48:CC) [11:26:21:682]: Component: UpgradeCode; Installed: Absent;   Request: Local;   Action: Local
File is called even though it is not included in the feature.
MSI (s) (48:CC) [11:26:23:682]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
MSI (s) (48:CC) [11:26:23:682]: Doing action: PublishFeatures
MSI (s) (48:CC) [11:26:23:698]: Doing action: PublishProduct
MSI (s) (48:CC) [11:26:23:729]: Doing action: ServiceInstall.cmd				//<-- Not selected ?????????
MSI (s) (48:CC) [11:26:23:729]: Note: 1: 2753 2: ServiceInstall.cmd 			//<-- Not selected ?????????
MSI (s) (48:CC) [11:26:32:977]: Produkt: ACSCore 2013 -- Fehler 2753. Die Datei 'ServiceInstall.cmd' ist nicht für die Installation markiert.
MSI (s) (48:CC) [11:26:33:071]: Machine policy value 'DisableRollback' is 0
MSI (s) (48:CC) [11:26:33:071]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Image of CA
Image of CA
MSI65A7-FehlerInstallation.txt
Log of installation
(106 KiB) Downloaded 250 times
Re: I have a problem with a CA in a feature installation.
Hi and welcome to our forums,
You need to customized the execution condition for the custom action. Besides the checkboxes you need to use the button "..." from the "Condition" field. This will open a new dialog, in the lower side of that dialog you will find a set of predefined templates for defining conditions.
There is also a template for defining a condition based on a feature action. So you can double click that predefined condition, it will then show you a new dialog from where you can select the feature based on which you want to create the condition.
N\sy
Thanks for the answer.
two questions occurred to me.
First: For selection of the component is actually taken into account before that this is associated with a feature.
Select Installed File Dialog
Second: Why then is 'Execution State Condition'
'Install' and 'First Time Install' believe that the CA is executed only if the feature is installed!
Why do you have now additionally define a condition? Actually it's already met, met to set 'Source Path'!
Please keep in mind that Windows Installer only verify if the component of the related installed file (used by your "Launch installed file" custom action) will be installed at run-time. But it will not skip the custom action execution if the feature (containing the component of your installed file) will not be selected for install. In this case Windows Installer will throw an "YourFile is not marked for installation" error message, but it will not skip the custom action execution.
So, in order to achieve what you want you should use the solution presented by my colleague in the previous post.
