Atlas
Disable Repair
This may be user error, I'm not sure. But I attempt to disable modify and repair in Advanced Installer like this:
Disable 1.jpg (29.22 KiB) Viewed 4529 times
However when the installer is run a seconds time, the modify/repair options still appear:
Disable 2.jpg (47.04 KiB) Viewed 4529 times
Am I doing something wrong?
Re: Disable Repair
Please keep in mind that the related "Disable Modify and Disable Repair" options will be applied only for "Add or Remove Programs" applet in the Control Panel.
In order to achieve what you want you can go to "Dialogs" page, select "MaintenanceTypeDlg" dialog and for [Modify] and [Repair] buttons set their "Visible" and "Enabled" attributes, from "Properties" right pane, to "False".
Atlas
Re: Disable Repair
Thanks. I appreciate it!
Re: Disable Repair
You're welcome. Glad to help.
