my1300m
Problem with parenthesis direction in Arabic language
Hi!
I have a problem with parenthesis direction in Arabic language in my multi language setup, here is a screen shot of my problem:
Is there a chance to fix this problem?
Re: Problem with parenthesis direction in Arabic language
Hi and welcome to Advanced Installer forum.
Sorry for the late answer, unfortunately I'm not sure how it should look in Arabic language, can you please help us with an idea?
Else, please give us some time to investigate this and we'll get back to you as soon as we have a conclusive answer.
my1300m
Than you Eusebiu!
I figured out that other Right-to-Left langs have the same problem for example: Urdu and Persian, I attached an image to show the right direction. Check it out.
Thank you very much for help, our team is already working to fix this problem and it will be available very soon.
my1300m
Hi!
I wanna know does the problem solved in current version? :?:
Yes. This issue was fixed starting with Advanced Installer 10.0.
my1300m
Thank you so much! It works perfect.
I have another problem in RTL languages... You can see it in this screen shot:
Indeed, this is an Advanced Installer issue, a fix will be available in a future version. Thank you for bringing it in our attention.
This happens because the "Advanced Installer" text is drawn on the background image and this image is flipped at runtime for the RTL languages.
As a workaround, you can go in the Themes page, "Images" tab and change the following images:
If you like, you can use the attached image.
Soft8080
Eusebiu wrote: Indeed, this is an Advanced Installer issue, a fix will be available in a future version. Thank you for bringing it in our attention.
I'm just wondering, when this fix will be available ?
It is very annoying to do the work twice (one normal + another flipped horizontally) whenever you want to change anything in the graphics (logo, backgrounds, ..). I thought it will be in the new version (v.11) but it seems not! I've already did a try and the bug still there..
I will be very thankful if this little bug will be fixed in the near future.
Indeed, this problem was not fixed yet, but I will increase its priority and hope that the fix will be available as soon as possible.
This was fixed in version 14.5 of Advanced Installer released on November 27th, 2017.
