tgillitzer
Empty field error in the Edit Control Event dialog
If I try to modify (to change the condition) the default published event (display a specific dialog), I get an error on the Edit Control Event Dialog (which looks like the old dialog, not the new one I see if I create/edit a new control event) that says "Empty Field Error - Please add and appropriate value in this mandatory field." with the arrow pointing to an area that isn't a field.
Screenshot attached.
It does this on a brand new AIP (enterprise) as well as old converted AIPs.
Re: Empty field error in the Edit Control Event dialog
I tested your scenario, but I couldn't reproduce the behavior.
Can you please tell us the version of Advanced Installer and the Operating System you have on your machine and also a step by step scenario so we can try to reproduce and investigate the problem?
tgillitzer
Version is 9.9.
Create a new enterprise project.
Go to dialogs
Go to FolderDlg under First Time Install
Click the Next button on the dialog
Click Published Events
Select the event "Display a specific dialog".
Click Edit.
Set a condition of "0"
Click OK
You should get the error I get.
This is on an Windows XP system. I haven't tested it on a Win7/2008R2 system yet.
This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
In the meantime, as a workaround, you can go in the Table Editor page, select the "ControlEvent" table and set the condition you want on the following row:
FolderDlg       Next        NewDialog       VerifyReadyDlg        AI_INSTALL
like in the example:
FolderDlg       Next        NewDialog       VerifyReadyDlg        AI_INSTALL AND (0)
Don't forget to undo this modification when the bug will be fixed.
Let us know if this helped.
udonmez
We are using your workaround,too. Waiting your bug fix.
br,
Unsal
This was fixed in version 10.0 of Advanced Installer released on March 21, 2013.
